My Hayward heater won't turn, is displaying a LO service code and won't get out of bypass mode. I have found the following troubleshooting tip but I don't know how to fix the problem.
Thanks!!!
The display will continue to show “bo” for 10 seconds, then “LO” will be displayed again.
a. If the remote thermostat does not generate a call for heat the “LO” error will continue to be a “soft” lockout. The control will accept keypad inputs to change the mode and it will remain in the selected mode when the error code is cleared. The heater will not operate until the error code is cleared.
b. If the remote thermostat generates a call for heat the “LO” error will be a “hard” lockout. The control will accept keypad inputs to change the mode and it will remain in the selected mode when the error code is cleared or the call for heat is removed. It will not be possible to switch out of Bypass Operation until the error code is cleared.
Thanks!!!
