- Sep 28, 2018
- 225
- Plaster
- Pentair Intellichlor IC-40
120v BRS 2 Part Doser - $70
Stenner 1/4" Injector - $15
5 Gallon Jug - $15
It's a 120v pump, so I hooked it straight into an intellicenter relay for easy automation. Already had a cheap outdoor box for the plug to easily swap it out if it dies... Also had some old 1/2" CPVC and a rubber washer that fit perfectly - I just cut slits in the bottom of the CPVC to allow acid through and then pushed the tubing all the way to the bottom so the CPVC is a guide not an actual feeder tube. To vent it, I drilled some holes under the vent cap and then holes in the side of the vent cap itself, then put a few dots of hot glue to prevent tightening it all the way shut.
It doses SUPER slow (~3.5oz/hr), so I'm not overly concerned about tanking the ph but would like to have some more safeguards in place.
Not super exciting, but it took me a while to figure out the best way to do this so hopefully it's helpful to someone - or please feel free to tell me if I'm about to destroy my pool for some reason I'm not seeing lol
5 Gallon Jug - $15
