- Mar 5, 2022
- 11
- Plaster
- Pentair Intellichlor IC-15
Hey there members. I’ve been taking care of my pool for about 10 days. I had a startup guy (recommended by PB). I’ve been working with my TF-Pro/Salt testing kit. As some of you told me, it’s not nearly as scary as I originally thought it would be. The only real problem I seem to be having testing is PH and CYA. I can’t seem to distinguish the colors in the ph test, and the CYA test seems to change on me (60-80) daily. I know I’m a little visually comprised, but can someone tell me if I’m on the right track with my chemistry?
I’ve watched my FC slowly drop, CC pretty stable at .5, so I increased the output on my iChlor 15 generator from 20% (set by startup guy) to 23%. Pool math suggested 21%. I run my pump for 12 hours.
My CH seems to be running in the 500’s. Is this kinda high, or ok? CSI has been ok lately.
I eventually want to add Borates to my pool, because I‘d like to help stabilize my PH and have that silky water Feel.
Hopefully you guys can see my logs and give me advice on my testing. I feel as tho I may be micro managing my pool, unnecessarily.
(Slightly stressful)
I really appreciate this forum and the members. I’ve learned a lot but have much, much more to learn. Thanks!
