1 week old new StoneScapes mini pebble
hchhuor
79
Beaumont, Texas
Fc 1
Ph 7.8
Ta 90
Ch 175
Cya 0
I added 39oz acid to bring ph 7.8 to 7.2
I add another 18 oz of Stabilizier. 8oz per skimmer. Last I’m going to raise fc from 1 to 3. Right before I go to work I will add calcium
hchhuor
79
Beaumont, Texas
I saw the Stabilizier that I added 48 hours ago still in my skimmer when I took the basket to clean. Sorry I don’t listen. I just add 18oz Stabilizier to the sock and leave it in the skimmer.
kimkats
38,286
Tallahassee, FL
Here is a link to the components for the FC test you should use instead of the drop one. The drop one is more for "Is there any FC in my pool?" kind of testing. The powder test is much better. FAS/DPD Chlorine & CC's test
Here is a link to videos to help you do it:
Once you get the water clear with the drops stop the test then. It can turn back to pick if you let it sit for a little while but don't worry about that. Once the water goes clear you are done with that test.
kimkats
38,286
Tallahassee, FL
I use liquid chlorine I get from the local pool store or Ace Hardware up the road from me. You need to add some each day or you will end up with algae. Here is a link to show you a basic pool care schedule:
hchhuor
79
Beaumont, Texas
I retest 10 min later after added 48oz of liquid chlorine. Fc 5 and cc .5
Fc 5 test second time after add liquid chlorine
Cc 0.5
Ph 7.5
Ta 80
Ch 175
Cya 20
Other Threads of Interest
