- Apr 23, 2021
- 5
- Fiberglass
- Hayward Salt & Swim 3C
Brand new pool , i was using chlorinating pucks in the skimmer temporarily ( SWCG was on backorder) and took the following readings:
June 11 : FC 7.0, PH 7.7, TA 60
June 14 : FC 2.3, PH 7.8, TA 47 (puck had completely disolved)
June 23: FC 7.0, PH 7.8,, TA 36 (had added a puck every 2 -3 days after they dissolved)
Water was christal clear
Then installed the new Hayward Salt and Swim 3C SWCG two days ago and PB set it to level 5 (30 mn chlorination active per hour). Salt is at 3300 ppm
(the Hayward 3C just has levels of chlorination that you set with + and - settings)
I just took a reading today (puck was removed at SWCG install)
July 1st : FC 18.47, PH 7.6, TA 0.
Dont know what is wrong. I am using the Lamotte Colorx and using test strips and they both concord. (TA is pale green on test strip which is equivalent or close to 0)
How can you have a PH of 7.6 while TA is 0 ? Puzzled (notwithstanding the huge amount of FC)
I just reduced the SWCG chlorinating level to 2 which reduced chlorination to 12 mn per hour while pump is running.
TA = 0 is off the charts ? what to do with this and the 7.6 PH
