+1The more you tinker the worse the exchange merits you. Leave it and finish the way it is then get the pump moving for a good few hours before testing to see the your achievement for the CYA.
Hello! Okay, my pool has passed the three criteria to stop slamming the pool. I am now waiting for it to come down to swimming levels. At 5:30 this morning my FC was 23 and at 8:30pm tonight it was 13. My concern is that it seems to be dropping fast. At this rate, it will 3 ppm tomorrow morning. First, is it normal to drop this fast? And, if it does then how do I keep it at sufficient levels without tabs? Or, are using tabs okay now? If I only use liquid will I be checking my pool daily and adding chlorine daily?
The use of LC requires daily testing and daily additions of LC to maintain your pool. You can swim with FC under your SLAM level for your given CYA level.At 5:30 this morning my FC was 23 and at 8:30pm tonight it was 13. My concern is that it seems to be dropping fast. At this rate, it will 3 ppm tomorrow morning. First, is it normal to drop this fast? And, if it does then how do I keep it at sufficient levels without tabs? Or, are using tabs okay now? If I only use liquid will I be checking my pool daily and adding chlorine daily?
Thank you! I like LC so it does not add any of the extras but wow I had no idea I would have to be testing and adjusting daily.Maintaining your pool with liquid chlorine will most likely require daily maintenance. The plus side is you won't induce conditions that require draining of your pool through excess CYA or Calcium levels.
If you have a good handle on your levels you can use tabs to manage things like short absences/vacations without causing problems.
Remember you want to keep above your minimum FC level at all times or you will end up slamming again.
Last Wednesday in a post, you stated you had a CYA of 50ppm. So on the FC/CYA Levels page. I put that in and shown in the photo below. For normal maintenance, you should always be in the Target Range of 6-8ppm. Never just sit at the minimum (shown as 4ppm) because there is good chance you will drop below that and you risk algae outbreak.I’m sure this is a stupid question but you say to keep it above”my” minimum. So, do I have my own personal minimum ? Or, is it just the 3-5 ppm range?
Also, how do I know how much chlorine to add to get it back to my minimum?
