Sounds GREAT. Leave the autocover open during the day so the UV can burn off the copious amount of CCs you'll be making.
The testing will tell you what intervals you need. Start with 2 hours (because you're around) and when it holds pretty well at 2 hours, go to 3 hours, then 4, etc. Go as late as you're awake. Usually if you hit it often on day one, it holds 4 to 6 hours on day two and up to 12 hours on day 3, plenty of time to go back to work on Monday for those starting on a weekend.
Of course, this one is a bit more than usual, but it will still tell you what it needs if you listen.
You can always dose early and buy your next X hours away (per recent testing) if you need to run errands or sit through a peewee soccer game.
