Small pool for the kiddo. 850 gal. New to pools. New sand filter. Rinse cycle blew dirty water back into the pool. Corrected the sand filter problem but now need to correct the cloudy water problem. Please help.
Welcome to TFP.
If the cloudiness is due to the dirty water that blew back into the pool, then the filter will take care of that. you may need to run your pump longer to enable that. Also best if you brush the sides and bottom so the water can be properly filtered.
It is important to ensure that the pool is properly sanitized. Please purchase a proper test kit to test the water. Test Kits Compared
