Two issues I need desperate advice on. Please help!! Our inground commercial spa was recently replastered, and small amounts of sand spit out. There is no indication of sand when backwashing, "rinse", or broken laterals. What do you think is the possible cause? Problem 2: After the replaster, 4 jets on one pump have very low water pressure. The other 4 work great on a separate pump. We have checked the venturi's for any broken parts or clogged sand. We installed two new pumps after the replaster due to leakage. We also found large amounts of broken plaster in the filter baskets. Could there be an obstruction of plaster causing the low water flow? Would a water bladder flush help? Your input would be greatly helpful as I looked all over the internet for answers, and the pool company that did the replaster is giving me the runaround.
