Planning to get a pool installed in our backyard. We are in SF Bay Area - so prices will be on the higher side.
Would really appreciate if people can give some guidance on the pool equipment used as well as the POOL COVER. Our builder recommends Jandy and even uses their pool covers (cover-pools is owned by Jandy and integrated into their automation system).
Also anything missing out here or something which doesn't look right?
Quote: $200,000 (North California) Pool Size: 12’6” x 40’0”, 437 square feet (pool) with automated cover Pool Depth: 3’6” x 8’0” Spa Size: 6’0” x 8’0”
Plumbing Specifications • Non-corrosive plumbing (Sch. 40 or greater) below ground as required • Builder to install hose bib on the equipment for emergency fire protection and lowering of pool water. • Manual fill line with brass anti-siphon valve installed. • Never lube Jandy valves (5 year guarantee on diverter seal) • 2 1⁄2’’ Pool Suction and Return Lines at 2” • Two Deluxe Anti-Vortex main drain covers in pool • One Skimmer in pool to collect floating debris. • Spa suction and returns at 2 1⁄2” , airline at 2” • Six rotary style spa jets included • 2” Gas line from meter location to equipment location included. Includes 1” stub at new firepit location.
Gunite • Specially engineered shotcrete structure, minimum 6-sack mix pneumatically applied • Continuous gunite inspection by crew supervision. • 22 sq. ft. of shallow end steps included per plan • 4’ loveseat with walkout steps in deep end included • Custom Bi-Level Seating in spa included
Electrical • 30amp main electrical run to equipment from meter location to equipment • Approved junction boxes for pool & spa lights at equipment • One convenience GFI outlet within 6-20 feet of pool edge at equipment • Pool Builder to hook up motors, lights, heater, filter, and control panel. • Four Jandy nicheless LED lights in pool one in spa included • Jandy PDA-PS6 automated remote control w/Jandy iAqualink smartphone controls included • Cover keyswitch at house included
Masonry • 6” Band of Standard Waterline Tile in pool and spa ($8/sq. ft. material allowance) • 16” x 24” Travertine coping included ($16/sq. ft. material allowance included) • Colored grout included
Equipment Specifications • Pump: One Jandy Stealth 2 h.p. ePump variable Speed Pump Included • Filter: Jandy 460 sq. ft. CV Cartridge filter for the optimum filtering and convenience for the homeowner • Heater: Jandy Jxi 400,000 BTU heater included • Air Blower: Polaris 1 h.p. air blower for spa jets included • Control System: Jandy PDA-PS6 automated remote control with Jandy iAqualink smartphone controls included • Light: Four Jandy nicheless LED lights in pool one in spa included • Pool Sanitation: Jandy Aquapure Salt Chlorine Generator included • Pool Cleaner: Polaris TR28P pool sweep included • CoverPools automatic pool cover with brackets for coping overlay included. He mentioned about some stainless steel cable system here (which will be an upgrade).
