Nitrates won't do anything.They got 0 chlorine, no ammonia, high nitrates (they said over 150ppm).
That won't help.The local pool/environmental health lady suggested trying some non-chlorine MPS shock as an oxodizer.
If the chlorine is getting used up, then the contaminant is getting used up.
It will eventually be completely used up, but we do not know how much is in the water.
If you can tell me what is in the water and how much, I can tell you how much chlorine it will take.
Dichlor increases cyanuric acid levels, so take that into consideration.At this point does adding 12 bags of this hurt?
Be very careful when handling powder shock because different kinds can explode if they get mixed together.
Never mix different types of powder shock together.
That might help.I’m getting to the point where it’ll be cheaper to drain most of the pool and have a tanker come with 12000 gallons of fresh municipal water.
Do not drain too much as the liner can come loose or the pool can be damaged if the water table is high.
I do not see anything on the report that helps much.
