Good morning.
I’m having an issue with high pressure on my DE filter. Everything seems to be working as it should. I have replaced filter grids checked for air leaks and everything in between but I can’t figure out where the problem is. I clean the filter and it’s up to 25psi within an hour with low flow. What could possibly be the problem. My next step is to replace the spider gasket. It’s basically flat and I can see pebbles imbedded in it. I can hear all sorts of sounds in the multiport while the filter is running. Could a bad gasket be causing the high pressure?
