The spider gasket in my multi-port was bad and causing a steady trickle leak out of the backwash exit pipe. Yesterday, I replaced it, and everything was working great, leak solved.
Today I rotated the lever to do a backwash. After the backwash and rinse, I put it back to “filter” and it was making a non-normal sound once I turned it back on. Additionally, water filled up the backwash port, and of course, there was a steady rush of water out of the backwash pipe.
I have removed and replaced the multi-port valve several times. To my eye, the gasket seems fine. All of the functions seem to work as normal, so I’m not doing a rinse when it’s set to filter or such.
How do I fix this?
How do I fix this?
