I have a similar problem. Super high suction and flow on recirculate, almost nothing on filter. Used on filter only a few hours. Could it be a bad spider gasket?
Yes there could be an issue with the multi-position valve (MPV). Suggest you test in several different positions - backwash, recirculate, waste and determine if all functions. It is best to always turn the handle in 1 direction to move between positions - go all clockwise or all counterclockwise.
The alternative is a very clogged up filter. When was the last time it was thoroughly cleaned? What is the pressure of the filter when in filter position?
