I have an ~8,000 gallon in-ground pool in Florida. My pool has a solar heating system as well as a dedicated pool vacuum suction line. The normal operating pressure was 10-12 PSI without running the solar system. I recently backwashed and cleaned my DE filter grids. Upon putting the pump in service I noticed the pool was now operating at 15 psi. Given my DE filter system was approx. 7 years old I decided that perhaps it would a good time to replace the filter grids. After completing the replacement and recharging the DE the pump pressure was still operating at 15 psi. If I turn on solar system the pressure runs at 20 psi.
I'm stumped as to why such an increase in both normal and solar operating pressure increases. I can lower the pressure by partially closing the Main Drain and Skimmer valves but I never had to do this in the past. Is it possible I have a bad valve on the suction or return lines? Is it possible I have an air leak?? I don;t see any water leaks in the piping or valve system.
When I use my pool Vac I have to partially close the Main Drain and Skimmer valves to get good movement for the vacuum.
