- Jun 1, 2018
- 13,946
- Vinyl
- Hayward Aqua Rite (T-15)
+1 on this. Life got in the way, good job maintaining your progress while you were traveling, and now it is time to resume and finish the SLAM. Since you used pucks, make sure you retest your CYA and adjust your SLAM FC level accordingly.Its close, but, unfortunately , not quite tfp clear.
I can see all holes in the deep end drain and I can see it has 2 Philips screws. I attached a picture but you might not be able to tell because of the reflection of the clouds. I still see some very small green spots in the stairs that were hidden by the cloudiness that can be very easily brushed.+1 on this. Life got in the way, good job maintaining your progress while you were traveling, and now it is time to resume and finish the SLAM. Since you used pucks, make sure you retest your CYA and adjust your SLAM FC level accordingly.
Keep going until it is crystal clear. While everyone's definition of clear can be different, I gauge it by looking at the drain. If I can see all of the drain holes and even tell if the drain screws are Philips or flathead, I call that clear. If I cannot tell if the screws are Philips or flat, then you are not there yet. Once you get to that point, then you can do the OCLT and CC tests to make sure you pass all 3 criteria. Good luck!
You will want to go down, remove the two Philips screws and scrub inside the drain.I can see all holes in the deep end drain and I can see it has 2 Philips screws.
Its hard to tell on the picture, but your comment about green algae spots is a definite fail of the clarity test. Keep going on the SLAM, you are almost there.I can see all holes in the deep end drain and I can see it has 2 Philips screws. I attached a picture but you might not be able to tell because of the reflection of the clouds. I still see some very small green spots in the stairs that were hidden by the cloudiness that can be very easily brushed.
I believe I will SLAM it again this weekend. I believe it can be clearer than this
Can I add 64oz mauratic acid at once? Or do I need to break it in 32 oz at a timeAdd CYA to 30 ppm now.
No need to deal with TA.Adjust pH to 7.2 and SLAM.
I usually mix 32 oz of acid with 5 gallons of pool water and dump along the pool edgesAt once is fine. Add slowly at pool return with pump running.
