I was short on chlorine today and wanted to save it to tonight till I get more tomorrow. I believe 5 ppm will prevent algae to take the upper hand and night time will kill what is left.This is definitely not the fastest or most efficient way but it is your pool. You’re not “saving” chlorine this way - the algae gets the upper hand when you don’t don’t replenish fc so the slam takes longer to complete. It’s like cutting the top 1/2 off a blanket to put it on the bottom. More work, takes longer - same blanket in the end.
Why not during the day and all those at night & get it done?
I added 2 lbs of CYA today to try and control the UV a bit. I used the sock method. But I can't see the jets on the deep end, so I added Infront of the jet I can see in the middle depth, does it have to be in the deep end? Will CYA damage plaster if it is shallow? I can see small granules leaving the sock and entering the pool and want to make sure it will not be an issue with the plaster because if so, I can just put the sock in the skimmer
