Hey guys, with bleach at $9 a bottle, I think I will make the switch to SWG this year.
I have a pool that is around 22K gallons and I am looking at this system.
I would like to get some thoughts on if this is the right one to go with and know if there are any installation walkthroughs, videos, checklists, etc to make sure I have everything. I just bought my TF test kit refill but I am sure I need a different one for salt. I also read on the forum to put the salt in 24 hours before, test, etc.
I know absolutely nothing about installing and maintaining SWG so I need to get learning and I am looking for any good resources.
One of the main things I need help with is where to put it. I will need to install it vertically. I can put it right after my filter, which I think is best because then it will work for the hot tub and everything. I can also put it after my heater but then it would miss the fountain.
The way my plumbing works is Pump -> Filter -> Heater -> fountain return -> hot tub return & pool return (main pipe splits into these last two)
You can see this in the attached pictures. The circle higher up on the image right by the filter is the area I am thinking about and if I put it there I may not need to mount it vertically. If I put it on the lower one I think I will have to mount it vertically.
The space of pipe up by the filter is 23 inches long and the space right before the spa/pool split is 12 inches.
Ok, thanks for any help. Let me know if more information is required.
Thanks
CircuPool EDGE40 Salt Chlorine Generator
CircuPool EDGE40 Salt Chlorine Generator-EDGE40, which I also found here for cheaper - https://www.amazon.com/Circupool-EDGE40-Salt-Chlorine-Generator/dp/B07Z8HQ333I would like to get some thoughts on if this is the right one to go with and know if there are any installation walkthroughs, videos, checklists, etc to make sure I have everything. I just bought my TF test kit refill but I am sure I need a different one for salt. I also read on the forum to put the salt in 24 hours before, test, etc.
Thanks
