It's good your pH and TA have not dropped low. The fact you are showing signs of holding the FC is good, so I think you are ready to introduce stabilizer to your pool so that you can transition into the regular
SLAM Process. Next time you check your FC, if it's between 8-10 ppm, add 30 ppm of stabilizer via the sock method. Then do your best to maintain an FC of "12" from here on which will be your standard SLAM level until you pass all 3 SLAM criteria. If you have any questions, or if your next FC test proves to be exceptionally low, let us know.
