- Jun 24, 2021
- 7,692
- Vinyl
- CircuPool RJ-60
There is a bacteria that eats CYA and converts it to ammonia. The bacteria is typically in dirt and blown in...How does the ammonia get in there when the water was crystal clear and all chemical levels were good? Is it not possible that the massive amount of pollen caused it? Just asking. The pollen after rain does leach into the pool from the solar cover!
You had zero CYA when you opened. When you added 3 gallons of chlorine it went away immediately. These are the hallmarks of ammonia. Re-read the article..just keep adding 10ppm chlorine until it holds above 5ppm. When it holds, ammonia gone.
See post #2...you are on the right track!!!
