Here we go again! No problems since the middle of June when I completed the slam. Been keeping a minimum of 3PPM free chlorine. Add 50oz at night. Check in the morning and have 5PPM. When I get home in the late afternoon it's at 3PPM. Awesome. Saturday I added about 3LBS a cyanuric acid. We've had heavy rains that added about 5 inches of water in the course of a week. This brought the cyanuric acid to 40PPM. I noticed the water was getting slightly cloudy on Sunday. I vacuumed the pool and backwashed the filter. The water was pretty cloudy coming out of the backwash. The pressure was only 2LBS higher than the start point which is 10LBS. The sand is 2 years old. Monday no change. Yesterday we had some very heavy rain that added just under 2 inches of water to the pool. Backwashed and rinsed to lower the level. I noticed this morning the water was a lot more cloudy and tonight I cannot see the deep end. The cyanuric acid dropped 15PPM and there was no chlorine. I added 192oz of 12.5% about half hour ago. Did a quick check of free chlorine and at least was getting a reading. Will check in the AM when the water has circulated over night. Is it possible that the combined high humidity heavy rain and water temp averaging 85 degrees over the last 10 days is causing this. The water temp hit 88 twice over the last 10 days. Solar cover hasn't been on for 2 weeks. Hoping another slam isn't necessary. Went from clear to cloudy in 24 hours with all levels good. Well chlorine was good until tonight.
FC 5PPM last night will check in the AM
PH 7.4PPM
TA 110PPM
CH 240PPM
Cyanuric acid 25PPM as of now from 40PPM last night
PH 7.4PPM
TA 110PPM
CH 240PPM
