- May 25, 2022
- 15
- Vinyl
- Pentair Intellichlor IC-20
I’ve heard several different opinions about back washing. I have a 13,000 gallon size pool. How often should I be back washing?
What type of filter do you have?I’ve heard several different opinions about back washing. I have a 13,000 gallon size pool. How often should I be back washing?
Thanks for the questions. Triton II sand filter. Yes I have trees and empty skimmer basket a couple times a day. I do need to monitor the pressure gauge a little more.What type of filter do you have?
How much debris falls in your pool? I.e. do you have lots of trees nearby and wind blowing leaves and debris into the pool? Is your skimmer basket always full?
Do you monitor the filter pressure routinely?
I have two DE filters that I never backwash. I just open and clean then when the pressure goes up. Usually about twice a year.
The standard recommendation states that when your filter pressure increase 25% above the baseline clean pressure you should backwash the filter. So if your baseline (clean filter) is 20psi then when it reaches 25psi you should backwash.Thanks for the questions. Triton II sand filter. Yes I have trees and empty skimmer basket a couple times a day. I do need to monitor the pressure gauge a little more.
Well, I’m a newer pool owner, only a few summers, so that’s why I’m asking more experienced owners.12,
It is your pool and you can run it anyway you want, but I suggest that you backwash for a reason, not because someone said to do it.
This is overkill- sand filters actually work better when they are a little bit dirty hence the tfp recommendation to wait until pressure rises 25% over clean pressure.Pool company that opens my pool tell me to backwash my system weekly. I’ve read different opinions on this.
