- Apr 2, 2024
- 5
- Plaster
- Pentair iChlor 30
So I placed a chlorine tab in last night over the spots, and now they are gone. Is it safe to assume that the spots were in fact algae? I have since found several smaller spots throughout the pool, so I keep repositioning the chlorine tab over those as well.TFP does not recommend using that product as noted in the link provided above. It can cause you issues down the road if it hasn’t already.
Have you done an overnight chlorine loss test to check for algae?
Overnight Chlorine Loss Test
Have you tried rubbing the area with vitamin C to determine if it’s iron/rust?
Have you tried putting a chlorine tablet on it to see if it diminishes?
Below is some additional reading so you can provide us with your test results if you’d like input:
Test Kits Compared
Pool Care Basics
PoolMath
Yes it could have been algae or other organic matter like leaf staining or something. Glad the chlorine tablets worked.Is it safe to assume that the spots were in fact algae?
2 caps fullIf the chlorine removed them, they were organic in nature.
How much of the YellowTrine did you add?
