I am curious to see what others have for fill water and whether its city or well water.
If you have city water then you must be the guy furthest away from the treatment plant since you dont have any FC. Here is mine on city water.
FC: 1
pH: 7.4
TA: 200
CH: 200
CYA: 0
We are at the end of the water line, at least on this side of the treatment plant.
Best to take a water sample from a spigot outside the house and closest to the main line running into your home. That eliminates sources of contamination from the house piping. I'll grab a sample later today from the spigot that my auto fill line is hooked up to as that will be the most accurate sample of what goes into the pool.
You guys that have low CH levels, do you have water softeners?
Fill Water Results
pHFCCCTCCHTACYA
8.2+
0.5
1.5
2.0
25
400
Hope you guys don't mind, but I put this in a spread sheet. I added all of the posts above this one already (If for any reason you don't want your results included, let me know and I will be happy to delete). If I get enough records, I might plot them on a map or something.
Better a TA of 400 than a CH of 400.
