Had my pool replastered last year with plain, white plaster and had significant issues with mottling and discoloration (see here). I followed NPC startup last time per PB recommendation. After a winter of back and forth, PB has agreed to redo the job, which is scheduled to begin at the end of this month. I have been extensively researching NPC vs Orenda vs Bicarb startups to hopefully avoid issues this time around. I would like to do bicarb startup, but I asked PB about Bicarb and Orenda startup and they do not support either method and they keep saying to follow NPC.
So what to do...
For reference, I just tested my fill water (city water from hose) and get the following:
FC=1.6, PH=7.0, TA=60, CH=100, CYA<30, TDS=200, TEMP=57 (likely will be higher at time of fill)
LSI=-1.26
LSI of fill water is obviously aggressive so at a minimum, seems like I should add Calcium Chloride to get CH =150 and Sodium Bicarbonate to get TA=100 (high end of NPC range). But even with these numbers I would barely have LSI=0. I am talking to someone at NPC to find out details on their recommendations. Just sent them my fill water numbers so waiting to hear back.
I see a lot of posts on bicarb and Orenda startups, but no long term follow up results. Does anyone have good (or bad) results they can report after a few years?
Should I ignore PB and do alternate startup method, which I assume would void my 1-year warranty?
So what to do...
LSI=-1.26
