Results 1 to 11 of 11
Thread: table showing relationship between pH TA and CO2 outgassing
    Jul 2012
    Whidbey Island, WA
    398
    Hi
    I saw on this website a link to a table showing the relationship of pH to TA and CO2 outgassing but...
    Cannot find anymore.
    Does anyone recall the link?
    thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: table showing relationship between pH TA and CO2 outgass
    search for posts by chem geek. I believe he's the one linked to it.
    Butterfly's Avatar
    South Carolina
    10,045
    You can search "pH TA and CO2 outgassing" in the site google search, top right in menu bar.
    Welcome
    You're done SLAMing when:
    Advanced Pool Chemistry. I believe you want the fourth chart down from the top.
    Jul 2012
    Whidbey Island, WA
    398
    different chart but same data, thank you
    Mar 2007
    San Rafael, CA USA
    12,082
    It's this chart in table format.
    Jul 2012
    Whidbey Island, WA
    398
    Quote Originally Posted by chem geek
    that's it! thank you
    Jul 2012
    Whidbey Island, WA
    398
    got it, thanks
    what does red / black mean? (sorry if I missed it)
    There are at least three colors involved, and I don't see any of them as black. Still, the color most like black means that outgassing will be slow, while the diagonal stripe of brighter red means outgassing will occur at some intermediate rate. While the bottom left darker red means outgassing will proceed rapidly.
    Jul 2012
    Whidbey Island, WA
    398
    got it, now see 3 colors, have old eyes
    am at TA 100 and pH 7.4
    if I drop to TA 80 or 70 or 60 to slow down pH rising will I hurt anything?
    Mar 2007
    San Rafael, CA USA
    12,082
    The dark color is supposed to be green. The colors delineate <10 (green), 10-20 (orange), >20 (red) which is how much the water is over-carbonated. However, the amount of pH rise is very dependent on the amount of aeration of the water so the color coding is very approximate and mostly for relatively calm pools. We have found that saltwater chlorine generator pools, for example, need a far lower amount of over-carbonation to be more stable in pH, closer to being 3 or less in the table. Finally, the rate of carbon dioxide outgassing is also proportional to the square of the TA level and that is not reflected in the table.
