Results 1 to 7 of 7
Thread: liquidator ?
    May 2009
    south jersey
    49
    liquidator ?
    Will the 8 gallon liquidator work with a pool that is 37000 gallons
    Vinyl pool 37,000 gallons 2hp hayward , sand filter, true L 18-41-16-28 - 9 foot deep end .. Solar panels with goldline automation ..3/4 hp polaris 380 ..BBB method
    Guest
    Re: liquidator ?
    Yes, but probably not real well
    I think that you are just a bit too big for the Liquidator to work, even if you did the upgrade. Punch some numbers for your pool in the Pool Calculator and see what kind of values you get. Then do the math on a 2 ppm drop in chlorine daily, and you should get pretty close to what you would need for make up bleach. I really think you are more of a candidate for a peristaltic pump at your volume.
    22,553
    Re: liquidator ?
    While I'm a fan of the LQ (liquidator) I agree with Sal's recommendation. Take a good look at a peristaltic pump and 15 gal tank system.
    May 2009
    south jersey
    49
    Re: liquidator ?
    Okay will do the pump rt what brand pump? Also for a 37000 pool I think I will need about 1-1/2 gallons of bleach a day 6%...
    22,553
    Re: liquidator ?
    I'd recommend the Stenner over anything else then any perstaltic over diaphragm any day. You can get a Stenner pump with a 30gallon tank. That'd last you about 20 days between refills.
    May 2009
    south jersey
    49
    Re: liquidator ?
    Were is the best place to buy one ?
    22,553
    Re: liquidator ?
    Just do a Google search for Stenner tank systems. Inyo Pools has about the best price I've seen on them.
