Thanks everyone. The PB is replacing the cell. We will work on getting the PH / TA under control next season. We had our water tested several times when the pool was open and everything was showing good except TA/ PH.
Local pool store was doing our water testing. Their reports show Saturation Index, Salt, pH, TA, Calcium hardness, Free Chlorine, Total Chlorine, CYA.
Guess I learned a lesson. New pool owner, will buy a test kit for next season and read up on 'pool school'. Yes, there is a mineral cartridge. We went with a pool installer who has been around for 50+ years with numerous locations. Their service is excellent. We trusted they knew what they were doing. Questioned that later when they had set the salt system to run 50% of the time which was wrong. Are you saying on top of the salt we should be adding chlorine to the pool? It was shocked with chlorine at startup.
No harm, no foul.. we are here to educate. And don't be afraid to ask questions. The old school Pool guys have typically not kept up with the changes in the industry. Even if you visit other pool support websites you will see a difference in the advice they give compared to ours. The TFP methodology is pretty well thought out. So be careful if you try to mix and match advice from other places. You can get yourself real confused if you do.Guess I learned a lesson. New pool owner, will buy a test kit for next season and read up on 'pool school'. Yes, there is a mineral cartridge. We went with a pool installer who has been around for 50+ years with numerous locations. Their service is excellent. We trusted they knew what they were doing. Questioned that later when they had set the salt system to run 50% of the time which was wrong. Are you saying on top of the salt we should be adding chlorine to the pool? It was shocked with chlorine at startup.
Your Nature2 FusionSalt is a saltwater chlorine generator. Your pool is a "chlorine" pool, it just creates its own chlorine. Your salt level is about 10% of what the ocean is. You should not need to add any additional chlorine unless you have an issue with sanitation or algae.
I have found the ones that have "been in business for 50 years" are the ones that know the least about anything modern. They not only started their company 50 years ago, they also stopped learning anything new in their industry 50 years ago.
I run no mineral cartridge in my FusionSoft. I just left in the block-out plate that was in it when it was installed. Your builder probably took your blockout plate when he put the mineral cartridge in. Perhaps you can get it back as they don't sell them and they are hard to come by. As an alternative, you can take apart an old mineral cartridge and just use the top. I run my variable speed pump 24 hours a day at low speed and set my saltwater generator at around 50%. That keeps my chlorine level around 7 which is inline (10%) with my CYA level of 70.
BTW: Which FusionSoft do you have? The 700 or the 1400 series?
