- Aug 2, 2022
- 25
- Plaster
- Jandy Aquapure 1400
1) My Pebble Tec pool is just over 3 months old and my Zodiac MX8 Elite is having trouble climbing walls for the past few weeks. It is connected to my vacuum line and I believe there is good suction, as I have the pool drain barely open and nothing else has changed. I cleaned it out, but it only gets about two feet up the wall before it is unable to continue. Is it possible there are some worn out parts? It took a bit of a beating early on, as it sucked up Pebble Tec residue. I also have been brushing the walls.
2) How often should I run the cleaner in the pool? I hardly ever remove it, and the pump had been running 12 hours daily until recently reducing it to 9 hours a day.
Thank you!
Thank you!
