Can you lower the RPM? That will save money. We don't have a salt water system. But we were told when we were considering one that the RPM would be low and run longer. I was under the impression you could run it longer at a very low RPM. But I don't know.
I can lower it. I just don't know what is expected for run times for our area as far as filtration. I want my water clear and don't want to have murky water but at the same time I don't want to be running my pool far beyond the necessary run times. I had my SWG set to 20% and in one day it went from 2PPM FC to 5.5PPM FC. I know this is winter so the demands are less. I turned it down to 10% for now and will see how it reads this evening. It is definitely a learning process.
I definitely have a love/hate relationship with the PDA system. I like how I can control my pool from the house since it is a flight of stairs down but it is SOOOO SLOWWWW. It drives me nuts. It is literally a minute or two before I can do anything on it. Plus I can't change the SWG setting without the pump running. Last night I went to adjust it after 8 and I had to turn the pump back on to change the SWG percentage. I write software for a living and this implementation is pretty poor if you ask me.
