Bumping this one, as I've got something new to ask about. First off, things have gone great (knock on wood). After getting the automation fixed, found the SWG worked great, running it 50% in 2 4-hour blocks a day and it's kept pace nicely. CHemicals have stayed nice and in range all season, and it's become as easy to deal with as I could have hoped for. Had to lower PH once or twice, add some water once a week when really hot, and otherwise totally on autopilot! So thanks all for that!
That said, question:
I've got a vinyl lined IG pool, and seems like liner over fiberglass steps (that's what it feels like, reading up that at least seems like a real option). No picture at the moment, but basically at the top step, it doesn't seem fully seated into the corner. In other words, while the step is still fully covered, right before you get to the wall (to go up to the coping), it isn't firmly attached to the wall. So there's a little bit of liner (really the length of the step) that's not really secured to the wall or the inside corner of the first step from the top. Does that make sense? Feels like there's some sort of bar or angle that was supposed to (or used to) clip into that area, but may be imagining things. Is that normal, or would there be a (non-horrific) way to fix it, or should I learn to love it and just be careful that I don't poke a hole in that part of the liner? Not really an issue except when the water is on the low side, but I make sure to keep it up so that more water is pressing it towards the wall.
Thoughts? I'll try to get a pic at some point, but think it's going to be hard to show. Basically if you picture the letter "L", the liner is just rounding the inside corner a bit rather than any attachment hard in the corner...
