- Aug 22, 2017
- 2,707
- Plaster
- Hayward Aqua Rite (T-15)
The Pentair driver in their VSPs aren't heatsinked adequately, hence they die an early death in an otherwise fully solid state design.
The only thing that dies in there, most of the time, is a proprietary motor driver that doesn't have the adequate heat sink. On an open market such parts range from $50 typically but in extreme cases $100, but you can't buy that proprietary motor driver on an open market.
So interesting that you brought this up. As my Pentair pump driver just stopped (most likely due to a lightning strike). The pump is still running, but the screen is blank (although backlit). I dont know if the RS-485 connection still works as the the strike fried my DIY controller which is now going through a rebuild.
