Sorry to make this opening so long, but want to try and cover how I got here as best I can (TL/DR below)...
A couple months ago when I first started working on the pool after winter, I upped the CYA level to 40 from 0, and added chlorine to mustard algae shock levels and maintained that for about 4 days (water only had a slight green tinge, no presence of mustard algae was detected, but we had a problem with it at the start of last year so just wanted to be safe). Water was crystal clear after two days, just still too cold to swim.
Since then, we've had TONS of rain and I knew the CYA would be getting lower, and instead of testing FC regularly like I should have, I've just been adding enough chlorine to ensure the FC stayed above 10 (too high, I know, especially if CYA has gotten lower). I know I should've been testing every day, but it was easier just to tell my son to go add X amount of chlorine and err on the side of too much to make sure no algae started growing before I had time to work on opening the pool. (this was the similar to the method I used over the winter, which I know caused FC levels to get too high at times because it bleached the blue diamond pattern out of the liner)
About 3 weeks ago we went out of town for several days and neighbor forgot to add chlorine for me, and when I got back the FC was at 0 and water was clear but had a slight green tinge again (barely this time), so I upped it to shock levels again and continued with my "make sure you have enough" method described above. Water was clear/colorless and sparkling again after just a day.
In the weeks since, it's developed a yellowish stain covering most of the liner AND the ladder with random spots that aren't stained. The sides don't feel slimy or rough at all, and no matter how hard I brush, it won't come out/off. When I tested the FC yesterday, it was at 15 after not adding chlorine for two days, so I know the FC level has gotten WAY too high. Not sure whether I'm dealing with a true stain, or some sort of scaling (with maybe dirt or algae mixed in?). The pool sits under a large oak so when it rains we got lots of yellow pollen and leaves in the pool regularly during the spring, which tends to turn the water yellow for a day when it happens.
TL/DR: I have a yellowish stain or scaling of some sort on pool liner AND ladder. I don't think it's algae because FC levels have been consistently high (even way too high) for 3 weeks and water is clear, but realize it could be. Walls are not either slimy or rough feeling. I've only (ever) used liquid chlorine and dry stabilizer on the pool (MA one time last year).
Test yesterday evening:
FC: 15
Test this morning:
FC: 14
CC: 0
pH: 6.8 (may be lower, as that's the bottom of the range on the test)
TA: 140
CH: 75
CYA: 20
Any help or guidance someone may have is greatly appreciated! Thanks!
FC: 15
Test this morning:
FC: 14
CC: 0
TA: 140
CH: 75
CYA: 20
