My liner is yellowing (especially in the white areas) as well as the baskets in my skimmer and pump. I thought maybe it was my liner getting old but why would my baskets yellow too? I have tried googling and searching for an answer but could not find anything. I've tried super chlorinating to remove it with no luck, I've had my water tested and there we no significant levels of copper or iron in the water. Everything else was in check. The pool tech at the store said that my water was practically perfect and they didn't know why i would have yellowing on these areas as well. I tried to scrubbing with my hand to see if the yellow go away and it does not. The pool tech recommended "off the wall" from bioguard to scrub the areas but not only does the entire pool need scrubbed (along with baskets) but it seems like a "i don't know so here" kind of response. I haven't changed anything in my process from last year to this, the only major changes i made this year is new filter sand. I can't imagine that the sand did that though. (I used majestic white II) My setup should be in my sig.
Any thoughts? Thanks!
