Hi all -
We're in MD just between DC and Baltimore. We moved into our foreclosure last April and proceeded to clean up the swamp that was the “pool.” Thanks to all of you we were able to swim all summer and into the fall.
Since we're still in off-season we thought now would be a good time to reach out to all of you for advice on updating our old systems.
Pentair Challenger 3HP (345209) for the main pool and looks like a 2HP Centurion (AO Smith) motor / Pentair pump for the waterfall and other features. (See signature or ask for more details if needed.)
We're thinking of leaving the 2 HP motor/pump for water features alone this year, it works fine and we don't use it a ton. Looking at the main pool pump though, we believe it's original and the pool was installed in 2004 so we're pushing 15 years. Would changing it out to a newer model help with efficiency or should we wait until it dies? Since we have a Paramount in-floor pool cleaning system, we think that it needs to be single speed vs variable speed. However, we aren’t 100% sure on that.
We're also considering installing a heater for the spa and pool. Pool won't be necessary as much as the spa. We'd like to use the spa year round. What are our options here? Looks like prior owners used to have both a propane heater and a heat pump at some point. Neither turn on or look to be in any shape to run and are probably due to be replaced anyway. (We do still have propane available, as well as 220v.)
Also, we’re really only planning on being in the house for about 5 years or so. While we certainly want to enjoy the pool during that time, we also don’t want to be installing more equipment (or more expensive equipment) than we really need to. For example, we may not need the most energy efficient option since our payback time is relatively short.
We were considering getting a couple of quote from pool companies just to see what they’d install. However, we don’t want to completely defer to them. We want to be smart pool owners.
