Hi All
So I am looking to replace my old halogen pool and spa lights. This is the light from the spa. I believe the pool one is the same. The pool was built in the late 80's/early 90's and the lights are of the same vintage. I can find no information on the light to tell me what it is. I disassembled the housing and there is nothing inside either.. other than the halogen bulb, some goopy residue from the leak and a disintegrating gasket. Given the age I am sure the housing and wire interface are no longer water tight. I don't even want to put it back in the pool while I figure out a replacement. The dimensions of the niche are about 5 in diameter and 5 inches deep.
What I want to do is put a new housing in this niche with a more typical incandescent type socket so I can put an LED bulb in it, as I have heard others do. I'm not interested in the fancy multicolored LED light shows that ready made LED units provide. Can anyone tell me what kind of enclosure that will work with an incandescent bulb socket will fit in this niche ?
Thanks
Thanks
