So I thought this was weird enough to finally sign up and move past my lurking days!
A week or two ago noticed a wet spot in our yard by the hot tub (kidney-shaped pool + hot tub, 25k gallon) where theoretically all the pool plumbing probably joins to go to the equipment pad. I am rocking a slightly high 4000ppm salt.
Trying to decide if it's the pool or sprinkler system.
None of the sprinkler heads seem to be experiencing very low pressure/no water coming out...
I had the bright idea to test the water in the yard to see if it matches the pool. The salt concentration matches our tap water, i.e. 200ppm or so salt. But the CYA test was positive for small amount 20-30 ppm cyanuric acid. Tap water obvi has no CYA. I tested it just in case, zero, totally clear. Why wouldn't the pool of water in the yard have any elevated salt level over tap but still contain CYA? Does that make any sense at all? The water might have just been dirty enough to look cloudy, I'm gonna re-test the CYA again in a bit. Shouldn't I be testing positive for both elevated salt AND cya in the yard if it's pool water?
Waiting on a pool leak detection company to come out. They apparently popular this time of year. Everyone with good reviews seems to be 4 weeks out. The pool isn't losing water fast enough to get a good bucket test positive against the Texas sun, but the yard also isn't wet enough to have hundreds of gallons a day leaking.
