- May 23, 2015
- 25,732
- Plaster
- Pentair Intellichlor IC-60
For the Maytronics robots, it's 43-95 degrees F (6-34 C) from the user guides I found. Sorry Matt, don't mean to seem like I'm following you around correcting stuff. Those just happened to be 2 things I knew offhand since that's close to the annual low temperaturein our pool. You're right that there's probably risk below that to be aware of, and I'm guessing @doug527 gets significantly colder water and then it freezes? In that case I would pack it up below ~45 deg and store for that part of the winter, but above that I am okay with the risks weighed against the big benefit of "Dive" (our E30) picking up the leaves all winter.
No worries, I pulled that 50F number from memory and I’m surprised I got pretty close.
Honestly speaking, I don’t believe a thing Maytronics states about their robots specs. They also spec an IP68 waterproof rating that is meaningless … the spec doesn’t even realistically test accurate pool water conditions but they can still say that they “pass” the spec. In that sense, their temperature specs might as well be pulled out of thin air too.
From an engineering perspective, the motor assemblies are poorly built to last in the conditions that most pool owners will use them. They are ticking time bombs in terms of failure. If a robot owner gets 5 years out of their bot, that’s as good as it get … any more time than that is just gravy.
