I have a 2” pvc pipe leading out of my backyard for my backwash water. Using a 3hp intelliflow pump. Outside of the fence for my back yard I have around 30 acres.
Instead of just letting the water run on the ground could I mount on of these on the discharge pipe and have it water part of my pasture?
1-1/2" Impact Rain Gun Sprinkler FNPT w/Nozzle Set - (12, 14, 16 mm) x 5 mm
This large sprinkler features excellent uniformity, long-lasting dependability, and is made for commercial agriculture. Operates in both full circle & part circle mode. Water cannon long range sprinkler for irrigation. Flow: 40-103 GPM, Radius: 65-108 feet, Pressure: 30-70 PSI. Aluminum pressure...
www.irrigationking.com
