AQUA~HOLICS
In The Industry
The rebar cage should have been continuous around that corner and not built out into the seat.
Great. How big of a deal do you think this is going to be? The crack right now is pretty skinny/ hairlineThe rebar cage should have been continuous around that corner and not built out into the seat.
Concrete can crack, so not necessarily a big deal, but you want to monitor the crack and the level to see what changes.Does it look like a serious problem to you? I’m kind of freaking out
Is this common for such a new gunite pool? Does it need repair?Concrete can crack, so not necessarily a big deal, but you want to monitor the crack and the level to see what changes.
Where the blue tape is the concrete wall is thick but has no rebar in it…The rebar cage should have been continuous around that corner and not built out into the seat.
No, it is not common.Is this common for such a new gunite pool? Does it need repair?
Do you have to drain the pool to repair it?No, it is not common.
It depends if the crack opens further and the pool begins leaking water.
There are structural gunite repair methods using epoxy injection or concrete staples to fix cracks.
Do you think we’re likely to see more cracks?
You got what you got.Do you think this points to a bad build?
Ughh
