I am about to start setting the coping stones and pouring the concrete around my pool. I have an 18'x43' Tee shaped pool with steel walls and a vinyl liner.
The coping I am using is 12 inch by 36 inch bluestone pavers. What I wanted to do was surrounding the coping all the way around the pool and from the pool to the equipment pad, is lay a 3 foot wide path of wood decking. My purpose was that the wooden path would be directly over all my plumbing. If ever I had an issue down the road, I could take up the wood, dig down, do what I needed to for repairs or additions and not have to break up concrete to fix anything or ad anything later.
Someone who has built pools before seemed unsure of this being a good idea. He said that it may cause problems with water draining through the ground and getting under my liner causing the liner to bubble up.
Here is a sketch of what I want to do:
Any thoughts or ideas?
Thanks,.... Mickey
Thanks,.... Mickey
