Apologies if this has already been covered in prior posts. What is recommended way to wire new SWG control unit to same timer controlling the pump? See my setup below. Power from panel comes in from below (120V 40A), runs to pump plug-in box, which also feeds light switch box and GFI outlet. Intermatic T101 timer controls the pump power, wired as shown. What is easiest/most efficient way to tied in power cable from new SWG to same timer control? Appreciated.
