I am installing a brand new sub panel outside for the new semi above ground pool at the house
I have a question about wiring the filter pump, the light, and the wifi timer
I have a suraielac wifi timer
it controls 2 accessories ( filter, and light)
so i have it set up this way
from the sub panel circuit breaker
hot and neutral and ground to the wifi controller in the appropriate terminals
- hot and neutral and ground to the outlet for the filter pump
from the outlet for the filter pump
- hot and neutral to the appropriate lugs on the wifi timer
hot and neutral and ground to the outlet for the pool light
from the pool light outlet to the wifi timer
- hot and neutral to the appropriate lugs on the timer
so each outlet and the timer have its own breaker
is that the right way to do it
or should i be feeding the wifi timer with power from its own circuit breaker
and than the hot and neutral lines coming off of the wifi timer go to each outlet (filter pump & pool light) and thats it ?
nothing else connects to those outlets
thanks for any help
thanks for any help
