Hello, I have a Whisperflo 115 volt 2 speed pump I need help
with the wiring.
Basically here is how it's setup. I have a Intermatic timer which
turns the pump on and off. The wiring to and leaving the timer are correct.
Next I have a simple 3 position toggle switch to control the speeds.
Left or right is high and low. Middle is off. Or to be more clear, the
pump doesn't run when in that position.
Next is the pump it self.
It has the usual three wiring hookups. #1 is for the power
# 2 is for high speed. 3 or 4 are for low speed.
I'm replacing the same pump with a new one. This pool and pump
are in Mexico, at our vacation home and while we were away, the pump
need to be repaired. That didn't go well, hence the new pump. When the pump was removed for
repair, some of the wring was remove also. Otherwise I could just copy what was there.
What I need help with is, from the timer to the toggle and then to the pump.
And yes, I have the factory 2 position toggle end plate I could use, but I'd rather
go with the separate toggle setup.
Thanks in advance for any help you can offer. If anyone needs pictures, I can supply them.
Lori robin
with the wiring.
Lori robin
