I have an Intelliflo VSF pump and an Aqualink RS4 automation system. My Aqualink is very old and I am planning to upgrade it to iAqualink but before I do that I opened up my power center to look at how it was previously wired. I discovered that I have an IntelliCom II hooked up. Is this necessary when connecting the IntelliFlo VSF pump to the newer iAquialink? When I YouTubed how to connect the pump to Aqualink all they said was to wire the green/yellow wire from the communication cable to the RS485 connector, no mention of the IntelliCom II. Will iAqualink be able to control the pump speed if I do it this way?
The way it is wired now, the Intellicom II 'Program 4' is connected to a 'Intake' valve actuator on my Aqualink. 'Program 3' and 'Program 2' is hooked up to 'solar' and 'electrical heater' for some reason but I don't have that equipment at all. 'Program 1' is spliced into the connector for 'Filter Pump.' The way it behaves now is that when I push the 'Filter Pump' button on my AllControl it will run 'Program 1' When I turn on the spa mode, it will run 'Program 4.' How do I migrate all of this over to the newer iAqualink? I understand that if I just reconnect everything as is it will work the same but with my current setup, I am not able to run a filter pump schedule with variable speeds. The other thing I can think of is that I can connect 'Program 2' and 'Program 3' on the IntelliCom to auxiliary connections on the new iAqualink which has 8 aux and schedule my pump that way? Is that the proper way to do it? I couldn't on my RS4 because I did not have enough auxiliaries. Or can the newer iAqualink do all this without the IntelliCom II.
