- Mar 26, 2020
- 8
- Plaster
- CircuPool RJ-60
Hey there! We just got our cell and flow switch installed on our plumbing (scary!) and now we've got the control module mounted up and are trying to get it wired to power. We have a Jandy variable speed pump and want to ensure that the unit only runs when the pump is on (double failsafe). The problem is that we can't seem to get power to the unit. We use iAquaLink automation systems and the pump is controlled digitally. We traced the wires from the top of the box labeled "filter pump" and connected the wires to the load side of the relay that they lead to, but nothing happened. We checked the fuses and all the connections and even brought it inside and switched it over to 120v, attached a household plug and were able to get power to the unit to test that it's operational. We also hooked it up to "aux 2" which controls the blower and heater and were able to get power there. But it simply will not work when connected to the pump relay (and the pump is running!).
I've attached a few pictures. Thank you to the volunteers who help us with this stuff
