Awesome thank you for your quick reply! The. I’m assuming you set the dial to the hottest setting so the OmniHub will always be able to turn the heater on.
I've wired the two wire leads to the following locations on the heater. What I am noticing is the OmniHub is not properly controlling the heater and basically if the flow switch is triggered by the pump being at the right speed the heater will kick on if the switch on the front is switched to on.Correct. Turn both thermostats up to max.
Hi James, thanks for your reply, yes this is what my heater looks like. See the attached pic of the plate.Does your heater look like this?
Is it a Minimax Plus?
Can you show the label?
It should work like you have it connected.I have a feeling one of my wires isn't connected to the correct spot (see pic) - black wire is connected to the wire that was plugged into the 'pool side' of the switch, the white wire is connected to the 'pool side' of the switch with all thermostat knobs turned up. When the switch is turned on to pool, the heater kicks on provided there is enough flow.
The heater is physically connected to the OmniHub Wiring Hub via the Heater LV1 (two wire) location on the control board. The heater does not turn off when you set it to off in OmniHub. If I adjust the thermostat down on the heater it turns off. If I turn the pump speed down to trigger the flow switch, the heater turns off.It should work like you have it connected.
The problem seems to be on the Automation side.
Where are you connecting the wires on the automation control board?
Does the heater turn off if the automation is set to off?
Can you show the part in the Omni manual where it shows where the heater needs to be connected?The heater is physically connected to the OmniHub Wiring Hub via the Heater LV1 (two wire) location on the control board.
