- Aug 18, 2018
- 74
- Fiberglass
- Hayward Aqua Rite (T-9)
Hello all,
I live in Raleigh, NC. We rarely get extended periods with temperatures below 32 degrees. I have freeze protection running on my inground pool, and it has worked great the last five winters leaving my pool open year-round.
My question is about a waterfall that is off the main plumbing and has a shut-off valve. I leave it shut off in the winter, and my thought is likely most of the water that would accumulate in the piping would be underground since water would be directed down (due to gravity) and not at the pool's water levels.
I prefer not to blow out the lines as I do not have the equipment to do so and would have to call out the dreaded pool company to do so. It also seems like a waste to have freeze protect run the pump through the waterfall as I would have to run the freeze protect at a higher flow to get water flowing through all the plumbing (since the waterfall does not have its own pump).
So my thinking, as it was last year when I chose not to blow out the waterfall line, is that the risk is pretty low that the waterfall plumbing itself will freeze if I keep its valve closed.
Any thoughts?
Any thoughts?
