- Dec 13, 2020
- 908
- Plaster
- Jandy Aquapure 1400
I keep reading that CH of 250 is about right. But using PoolMath with my situation in the winter:
pH 7.8
TA 60
CYA 65
Water 40F
Salt 3000
It takes CH of 650 for a CSI of -.30 . By summer water will be 85F+, and CSI will be +.13. I don't like the idea of being in plus territory with a SWG.
How do folks manage this annual fluctuation? CH of 650 seems awfully high. With the nominal recommended pH of 7.4 it would be worse!
I've never had problems with scaling - including SWG plates. The grout and plaster of my 16-year-old pool seem fine.
When we moved in 2.5 years ago, indeed CH was ~200, which is about the fill water level. I raised it to ~450 and kept it there. This just requires a tweak now and then for overflow losses.
But it's cold again and PoolMath is causing me concern.. Not sure where to go. Just stick with 450? Or go higher now and worry about scaling later?
pH 7.8
TA 60
CYA 65
Water 40F
Salt 3000
