Hello,
I noticed this afternoon that a section about 4 feet wide on my 15 x 30 pool has shifted about 4 inches out from the bottom. Just one section though and my deck appears to be holding the vertical post of the pool from falling. Attached is a picture from the underside of the deck and labeled the points of concern by number. Also a picture from the top side, I circled the post that shifted.
Label 1. There is now a mound of rocks from where this slid and pushed the rocks.
Label 2. This support post moved straight out vertically, I suppose the deck stopped the top from moving out further.
Label 3. In his area along the base, the rocks are also moved and kind of looks similar to a line that moles make in a yard.
I don't see any major divots in the pool liner BTW.
I am draining the pool now but does anyone know if this pool be saved? The pool is about 15 years old.
Please let me know if anyone has experienced this or can give me
some advice. I can also provide more pics if that helps.
Thank you!!!!!
Thank you!!!!!
